RCU Forums - View Single Post - Extra 260 (SD-models) trim question
Old 12-05-2007 | 08:51 PM
altavillan
Default RE: Extra 260 (SD-models) trim question
Put a long straight edge along the side and see if the pins are all parallel. If the plane doesn't change pitch when accelerating then it has to be stab to wing incedence out of alignment or a weight/ballance thing. If it changes pitch going from idle to full throttle then it a thrust issue.
