ORIGINAL: GalenB
ORIGINAL: martinarcher
How hard is it to pull the rudder.
Very easy if you hinge it right. If you use Dubro heavy duty hinges and a piece of 0.047" music wire you can remove the rudder very easily. Simply remove the hinge wire and detach the pull-pull cables and it's off.
Great idea - I like it! Might allow me to haul one of these babies.
Excuse my ignorance - I'm new to the giant scale stuff...
Do you need to drill an exit hole in you tailgear strut to pull the pin out through the bottom?
How to you keep the pin in once you push it in?
Thanks!
