RE: Extra 260 (SD-models) trim question
That's exactly what mine did and I had to put up thrust in it. Now it flies level at all throttle settings and is neutral either inverted or right way up. The down thrust caused it to pull down under throttle and work against the flight surfaces. BTW My CG ended up at 6" back which, as you know, is not where they say it should be.
