RCU Forums - View Single Post - XTM Monster MT
Old 12-05-2007 | 11:09 PM
Nick2618's Avatar
Nick2618
Default RE: XTM Monster MT
ORIGINAL: SavageSpawn
How does this compare in size to the LST and Cen Genesis?
XTM Is slightly longer Gst is Slightly wider. Both have same ground clearance. And LST would look small compared to both of them.
XTM
Specifications:
Length: 25" (63.5 cm)
Height: 12" (30.5 cm)
Width: 17" (43.2 cm)
Weight: 14 lb (6.35 kg)
Wheelbase: 16.5" (41.91 cm)
Tire diameter: 7" (17.78 cm)
Ground clearance: 4" (10.16 cm) with suspension extended
GST
Length: 23.1" (587mm)
Width: 18.4" (467mm)
Height: 11.8" (300mm)
Weight: 15.4 lbs (7kgs) approx.
Wheelbase: 15.63" (397mm) wheels on-center front-to-rear
Front and Rear Tread: 15" (378mm) wheels on center side to side
Front and Rear Track: 17.75" (451mm) wheels at outer edges
Ground Clearance: 4" (102mm)
Suspension Travel: 5"
Tires: Diameter 7.5" (190mm), Width 4" (102mm)
Wheels: Diameter 5.2" (132mm)
