cutterboy - the cx has a built in rate gyro to hold the head steady when you are hovering, but cuts out when you move - sounds like the gyro gain is a little too high - this can happen when you change the weight of the heli - you need to adjust your gyro gain - it's in the manual - go slow and change by tiny bits, fly and see if its better
docnee - if you look at the heli from the side with the blades spinning fast but not quite at take off speed, you will see that the blades are probably out of track
http://www.heli-max.net/mediawiki/in..._and_CX2_Setup
edge
