Exploding Covering...
Is it a dark covering that gets heated by the sun? I had a wing with dark covering that puffed up from trapped air being heated between the ribs. Now I always put a small vent hole in each rib so the wing can breathe out thru the servo holes. Sounds weird, but it solved my problem!
