RCU Forums - View Single Post - 42cc engines?
Old 12-06-2007 | 12:37 PM
tim220225's Avatar
tim220225
Default RE: 42cc engines?
Prop hubs aren't something you can get off the shelf in most cases. That thread size is very common on the engines I have converted. The real issue is the taper on the crankshaft and the diameter of the crankshaft. I have seen most manufacturers have the same crank diameter but have different tapers on the shaft.
