ORIGINAL: KC36330
i decided to give it a go on an old composite wing i had laying in my garage. normally you spray the glaze on cabinets, it hazes over about as quick as you spray it to keep it from burning into the finish to deeply and then you use a Scotch Brite to buff it off leaving all details behind. i wiped the wing down good with alcohol to clean it, used a stain rag to rub the glazing on and then after about 5 min of elbow grease with the Scotch Brite it looked pretty darn good.
Old composite wing????? That looks like a spanking new Tam A-4 wing!!!
