RE: Constant speed propeller
Juice,
The prop is mechanically linked to the engine, so the engine is constant speed as well. The throttle is controlled by the pilot. The prop typically gets its signal from the engine oil pressure to vary the prop pitch in order for the prop/engine to maintain the same speed. The pilot monitors engine load (power) by the manifold gauge. Some new electronic equipment may be a bit different.
Bedford
