RCU Forums - View Single Post - Constant speed propeller
Old 12-07-2007 | 12:38 PM
Juice
Default RE: Constant speed propeller
My mind is stuck in the fixed pitch world of RC aircraft. []
In simple RC engines, the throttle input (Tx stick) is proportional to the amount of fuel/air flow (carburator), which is proportinal to the engine and prop RPM.
My trouble is imagining this... at low throttle the fuel/air flow is also low (producing a small bang at combustion), but the engine is still at the constant RPM (presumably high RPM).
This is possible because the props would have been adjusted to a very low pitch and the load on the engine is very small.
Small bang + light load = high RPM
Big bang + high load = same RPM
Am I thinking right?
Juice
