Ian, you've got too much lift. A good back cut will work wonders for you. I'd mark off 1mm from the hub and file down trying to profile each blade. Run it & see how it does. Try another .5mm & run again. After about 2mm you'll see a difference.
Same prop, just showing an example of a back cut on the left blade.
