RCU Forums - View Single Post - Split Aileron Servo
Old 12-07-2007 | 01:59 PM
sscherin's Avatar
sscherin
Default RE: Split Aileron Servo
It's a simple bit of cutting to widen the servo mount for 2 standard servos..
I did it on my Cloud Dancer and it worked fine.
each servo used 2 of the original screw holes so I only had to make 4 new hold for the outside screws.
I used short Dubro single arms and it still fit inside the Cloud Dancer fuse.. It's not exactly a wide body..
One thing to think about..
A micro may be half the width but it's also shorter so you'll have to add a new mounting block.
That will make it harder to go back to a singe standard servo if you don't like the setup.
I guess you could make a try for the micros that screwed to the standard servo mounts.
