RE: Help needed - OS FS 70 four stroke Valve Spring replacement
There is a disk and a little C-clip that hold the spring in place. You must push the disk down and slide the C-clip off the valve. The the valve spring retainer disk should liftoff. Then you should be able to lift the spring pieces off.
