RCU Forums - View Single Post - Multiple motors on one speed control
Old 12-07-2007 | 05:57 PM
DaveFlynn
Default RE: Multiple motors on one speed control
BEC's in parallel: Some linear voltage regulators will oscillate when hooked up in parallel. Read the docs, some mfgs say theirs will work in parallel increasing the current available for more servos. If the docs don't say then you can test with a meter to see if the voltage remains stable when they are connected together, move the servos and throttle, if the voltage jumps up at all then don't use them in parallel.
