RCU Forums - View Single Post - Extra 260 (SD-models) trim question
Old 12-07-2007 | 06:03 PM
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RE: Extra 260 (SD-models) trim question
I found another problem with the Extra yesterday: the stab tube did not align perfectly wit the wing tube (left lower than the right). See picture 1.
I ended up removing the stab tube socket, rolled a new fiber-glass one with 2oz cloth. See picture 2.
Then I adjusted the mounting hole on the left fuze, and installed the new socket. The stab tube is perfectly aligned now. See picture 3.
Will try more up-thrust idea and report back.
BTW, the alum stab stub is 1.4 oz in weight. If replaced with a lighter carbon fiber one, some nose weight (if any) can be removed.
ID:	820542   Click image for larger version
ID:	820543   Click image for larger version
