This article
http://www.dubai*********.org/propeller_faq.htm has a very good write up on prop selection and discusses how to decide if you need large diameter, low pitch or smaller diameter, higher pitch.
The short answer is it depends on your application. Large diameter, low pitch for slower flight with more power. Small diameter, high pitch for high speed with less power. This is based on props that provide the same RPM.
Dave
