RE: axe cp thread
You should have no problems changing the blade grips and it not flying after the switch. Make sure you didn't hook the linkage wrong - the horn on the blade grip goes to the trailing (REAR) of the blade, and the leading edge of the blade is on the clockwise side looking down on it. The linkage should come almost straight up to the flybar carrier.
