ORIGINAL: xcead
but the pull pull sistem , used by quique, worked fine to win the world championship
DESPITE THE OBVIOUS FLYING ABILITIES.....this sistem, won the WC, so it isnt too much " rolling elevators " coupling...
i dont know...the plane was equiped with that sistem
the world champion wouldnt use it if its not good...
IMHO...
You got it..... Pull-pull on elevators works just fine. Have done it for more than 20 years that way
Frank I. gave very good info. I would add that as long as you place the servo output arm in the center of the fuse, both latterally and vertically, it will matter very little whether the servo is upright or sideways. Upright is a simpler set-up but sideways is a very slightly more accurate set-up....but hardly enough difference to notice.
MattK
