ORIGINAL: NitroNuisance
You really need 6000kv? I'm new to boats but everyone is telling me to go low KV. What about this
https://www.unitedhobbies.com/UNITED...idProduct=2068 It's only 5639 kv. I just ordered a feigao for my mini-v project and after talking to others on here I whent with a 2500kv. I origionally was going to get this motor.
Nitro,
Using a 6000kv motor with a 6v battery doesn't result in extremely high RPM. Because of the rather low voltage of a 2S lifepo pack I need that high kv to get the RPM output that I need. So 6000 x 6 = 36 000 Rpm.
The same story in a car on 6 cells would give you 6000kv X 7,2v = 42 000+ rpm's. Most boats are direct drive without some sort of gearbox that cars use ( diffs and pinions and spurs ) so there is a difference here.
Higher RPM leads to cavitation indeed , but that mostly is because the prop that is used is to small or the strut is in a bad position or the weight distribution isn't correct. RTR boats like the SV and stuff don't have a correct weight distribution most of the time.
