RCU Forums - View Single Post - Props vs Thrust?
Old 12-09-2007 | 10:01 AM
dbacque
Default RE: Props vs Thrust?
So low speed? Go with large diameter, low pitch. This will give highest static thrust and lower top speed. Be sure that the prop you select allows your engine to turn in the correct RPM range to be in it's power band.
Dave
