RE: engine tuning problems and more
You are set too lean. You don't adjust for max rpm, you want to be on the rich side. Go to full throttle and pinch the fuel line just before it gets to the carbeurator. You should hear it rev up some before it lets off. If not adjust richer on the HSN. Then you can try to point the nose up at full throttle and it should stay at same rpm.
