ORIGINAL: Flylow
Thanks for all the replies. I finally got a chance to look this thing over real good. Seems very well built and the covering job is excellent! Gonna have a lot of fun with this plane. I see Checklst added some tail weight even with a tailwheel servo mounted in the rear. Checklst, how do you keep fuel from siphoning to the inverted Saito?
I lowered the tank and drilled a second hole for the lines. The tank center line is now on the 72 carb center line.
