RCU Forums - View Single Post - Kangaroo-NitroPlanes-Assembly
Old 12-09-2007 | 06:10 PM
Crazy4Flight's Avatar
Crazy4Flight
My Feedback: (540)
Default RE: Kangaroo-NitroPlanes-Assembly
I cut the Horizontal stab open to install a Hitec HS-125 MG servo. Made a hatch and itis ready for assembly.
The wood dowels supplied are less than 5.5 mm in diameter a SLOPPY fit for 6 mm holes.
A trip to the Orange store got 1/4" dowel to sand down to a good fit a 6mm.
Rudders will be added to the fin panels.
Servos will be place in the original elevator pockets.
I will fly the plane using Elevons mixing, JR sport 125 mg servos supply more torque than needed.
My Futaba 9CA P-mix elevator to an aux channel to drive the real elevator.
Most delta wings need plenty of elevator throw.
With this set up I will hve plenty of control authority.
ID:	822257   Click image for larger version
ID:	822258   Click image for larger version
ID:	822259   Click image for larger version
ID:	822260   Click image for larger version
