RE: Echo BME twin
Foamcut I have looked at a bunch of cylinders over time. Most could work as the issue is in the pin on the case. I would need to look through the base gaskets I have and see how many fit the original cylinders and cross them to the bigger cylinder that uses the same gasket. Drill new holes for the pins and it would probably be OK.
