RE: PassTime Perigee Build thread
WEDJ, I have to admit I too cheated with Toms design...mines 10% bigger (66" span) which was easy, given that I used the mag size plan and just enlarged it at the local copy shop. I used the same wood sizes as the plan called out, uses an LA.46 inverted where the nosewheel should be and the wheel on the firewall former behind the engine. 8oz tank with plenty of room behind the engine, 1deg washout on the wing tips, 5lb 0oz. unfuelled. Still snaps on command, but lands like a *****cat. Hard to choose between this and a Taurus, but the personality of each is really different.
Evan.
