RCU Forums - View Single Post - Help selecting a prop?
Old 04-06-2003 | 02:29 AM
warbirdz1
Default Props......
Neo....You'll find a whole slew of ideas for this one........If its "aesthetics' you want ...I would go with a "static" prop and then choose a performance prop not being concerned about how it looks....I have done alot of "prop testing" if thats the correct term and found the "zinger props" are too-thin in the hub area and flex alot...had 1 of them explode in flt and heard others have had similar failures..........On my "Z" B-25 for example I have MA 3-blades done-up for static and run Menz 18x10 for flying.....on my "Z" P-47 I have a Q-75 for power and run a 22x12 Menz for performance...I use a smaller dia prop with more pitch for speed.....can use a 24x10 but too slow for me....... on a 3.2 such as you have(similar to G-62)...I might try a 22x10 or for more speed a 20x12 menz.........You'll find each plane responds alittle different to a selecBill.....ted prop......Once you've chosen a prop...paint it as you would like.....I just use a light coat of cheap enamel paint(black) and then paint the tips yellow....Bill....
