RE: Tx X9303 Rx 6200 Rx pwr on Throt not safe
>>Not sure if you are talking about a nitro or electric.
It is nitro, no ESC or BEC involved.
>> Have you tried another rx?
I have just setup a second similar plane using second 6200 receiver and it does the same thing.
>>Did you rebind your system after aircraft setup.
Yes. I am following the instructions that come with the receiver, bind plug into a 3 wire switch, rebind after programming.
And I gave some incorrect information: It does not go to open throttle, it does nothing. I turned the throttle servo to open manually to see if it would go closed when rx power turned on. It does not. The servo has no signal and just stays where it was. Until I turn on the Tx, I can manually move the servo because it has no signal.
It appears that the 6200 thinks I am flying an electric with an ESC.
Oops, my bad. As we used to say, RTFBD.
I just re-read ALL the binding instructions carefully. It is WAD (Working As Designed)
