RCU Forums - View Single Post - Summit III for Pattern?
Old 12-10-2007 | 11:27 PM
MTK
Default RE: Summit III for Pattern?
ORIGINAL: navav2002
ORIGINAL: MTK
<snip>
Lengthen the pipe to approximately 15" to the high point of the pipe, measured from the glow plug, straight line.
Good luck
MattK
<snip>
That should be pretty hard on the Razors Edge isn't it?? I'm personally a bit more conservative than that...
I was tuning an AR today...I settled on 16.7" from the glow plug to the High point on a Hatori 650, Turning 10,200 RPM's on a 12x12 APC, PowerMaster 20/20 fuel and an OS#8 plug...(Just breaking in)
Was running one of my std LS's Saturday and got the same length(16.7) on the Hatori 650...It's turning a 12x10 APC @ 10,300 RPM...
Some of threads I've researched recently the guys were running the Hatori 650's longer than that (17-20 inches) with the YS 61LS...
Sorry to contradict your expertise...I probably normally wouldn't ...But I just did it today...So I thought I'd share my experience...
Have Fun...
Chuck
P.S. I want a Summitt III also...
No need to be sorry. As I mentioned earlier that's as close as I remember, 12-15 years ago. This is supposed to be educational forum and trying to get as much truth as possible....no contradiction present.
Having said that, there was a primary baffle approximately 2" aft of the high point, if memory serves. That placed the baffle approximately 17" aft of the plug. Are you measuring to the high point or to the baffle?
The high point was just a convenient way to measure. The baffle is the real desired measure. It's the reflector that causes resonance and hence the power boost.
Bryan, one simple way to check if your pipe is too long, put the model in a shallow 5 degree dive to unload it. If the engine goes fat, pipe is too long
MattK
