RCU Forums - View Single Post - Blackjack 26 Electric speed control problems
Old 12-11-2007 | 02:07 PM
itduz11s
Default RE: Blackjack 26 Electric speed control problems
[>:] [size=2]I’m having problems with my ESC (Stock BJ26) cutting out as if the batteries were low while in the water... While I saw researching my problem I came across your problem... The ESC is in the BJ26 is designed to cut out if there is no water presser on the prop to prevent damage to the motor… As long as it runs correctly in the water you should be ok… if you still have the twitch or glitch while running your boat in the water you need to look into your radio… As for me I’m still looking for the answer to my problem… I will look into the receiver being wet as Headhunter23 suggested… Other then that I’m afraid I’m looking at a new ESC in my future… Anyone able to steer me in the right direction for a new ESC??? Right I’m running two 7cells and I want to step up to Lipos in the future… I’m also running the stock prop and stock motor.
