RE: G & L Hobbies Extra 300 build thread
I would definitly say yes. Make sure when you get it to wash it good with a mild soap inside and out to remove any mold release. then scuff the area good where the former goes and spray a bit of water on one side and glue the other. should foam up and real nice and hold well. I used 30 min epoxy I got from Hobby Lobby craft store, mixed micro baloons in and stuck it.Rember if you use it to sheet the wings keep and eagle eye on it cause the foaming will move the skin around and get it out of place.it takes 30 - 45 min for it to set and most of the foaming to stop. I am sure the build will be very close to this one and if I can help you pm me . I have seen this kit at Gregs and it looks like a nice kit. He does top notch fiberglass work . The build is faster than a wood kit and weighs about the same.
