RCU Forums - View Single Post - Engine problem
Old 12-11-2007 | 06:07 PM
Big feet's Avatar
Big feet
Default RE: Engine problem
Hi,
As the engine runs it begins to bed in and turn over freely. This effects the rpm's and therefore mixture.
As the flight proceeds the engine heats up and you loose power.
You will need to re-tune the engine. If you look on the engine fourm you will find really good info as to the method to use.
Hope this helps,
