RE: G & L Hobbies Extra 300 build thread
Well I did not do much building this evening but I did do quit a bit of sanding. Getting everything ready to install the leading edge and trailing edge.I will be using Titebond carpenters glue to install a piece of 3/8" balsa to the leading edge and a piece of 1/4 " balsa to the trailing edge.Hold it together with t pins till dry.
Greybeard, I will try to get some photos in the next nite or two showing how I will do the servo pockets. I have a spiral cut routerbit that should route a nice clean hole. I figure I will have to freehand it.
