Turning Wheels
the big gear that the clutch bell turns(clutch bell is the gear attatched to the motor,it turns the main gear(spur) witch spins the diff)well the easiest way to say it is grab ahold of the biggest gear on the buggy (while it is NOT running )and turn one tire if that dose not make the diff react then you have a problem.
