RCU Forums - View Single Post - rounded nut
Thread: rounded nut
Old 12-12-2007 | 04:55 PM
chedster
Default RE: rounded nut
If you use a small drill bit with your drill you may be able drill the head of the screw until it breaks off, then remove the engine and carfully use pliers to carefully remove the rest of the screw. I have never done it on my rc cars but have on many other aplications, it should work if you're careful.
