RCU Forums - View Single Post - Cuda canopy
Thread: Cuda canopy
Old 12-12-2007 | 05:05 PM
as722
Default RE: Cuda canopy
It should be flush all the way around. The easiest way I have found is to cut some balsa sticks 3/8" x 7/16". This will give you a 1/16 on each side and once the canopy is on you can sand the fuse sides to match the canopy. As for the back of the canopy frame, just trace the front of the turtle deck on the 1/8 balsa and cut it on the inside of the line. This will give you the correct gap for the canopy assuming your blade isn't bigger than a 1/32" or so. I hope this helps.
Albert
