Heli Mike 81,
The HBK2 is in between the size of the CP and a Trex 450. Had 'em all. When installing a Scale Body, the one thing that it does, is add alot of weight. Unless you upgrade your CP to a brushless motor (a gyro would be nice too) I don't thing the stock motor on a CP would lift it off the ground. That hold true for a Stock HBK2, you'll need the extra power and head speed that the brushed motors won't give you. Myself, I'd vote for a HBK2 with a 3800kv motor and a 10 tooth pinion. The 8 tooth won't give you the head speed you need. Not sure about the 9 tooth. But the 10 tooth has plenty of punch. You could even go with an 11 tooth pinion. An 11 tooth on a stock HBK2, makes it rock. Also, the HBK2 has a belt driven tail rotor, so you don't need to worry about tail motors going out, or readjusting the proportion mix all the time either.
Dave / Choppersrule
ORIGINAL: Heli mike 81
i went to that site and was looking at bodies... alot of the ones that fit the HBK2 also fit the CP... is the HBK2 any bigger than the CP? id rather not spend $200 to get the same heli i have now...
btw.. i love the hughes 500 bodies...
