RCU Forums - View Single Post - Coke can carb fix
Old 12-12-2007 | 07:12 PM
Truckracer
My Feedback: (19)
Default RE: Coke can carb fix
ORIGINAL: Al Lewis
I drill the hole slightly larger then the tube so it's not air tight. Just keeps the end of the tube away from any possible turbulence in the fuse.
I use the balsa box method suggested here on the forum several times. Just one pinhole in the box .... the porous nature of the wood seems to work very well for some reason.
