RE: ARFs in SCALE CONTESTS
The dictionary defines a scratch builder as…. (Per WikipediA)
Scratch building is the process of building a model from raw materials, rather than building it from a commercial kit, 'kit-bashing' or buying it pre-assembled.
Scratch building is easiest if original plans or other technical drawings of the subject exist; however, many models have been built from photographs by measuring a known object in the photograph and extrapolating the rest of the dimensions. The necessary parts are then fashioned out of a suitable material, such as wood, plastic, plaster, clay, metal, Polymer clay, or even paper, and then assembled. Some purists consider a model not to be truly scratchbuilt unless all of the parts were made from raw materials. However most modellers would consider a model including commercial detail parts as scratchbuilt.
The reasons hobbyists scratchbuild may vary. Often a desired model is unavailable in kit form in the desired scale, or entirely nonexistent. Sometimes the hobbyist may be dissatisfied with the accuracy or detail of kits that are available. Other times a hobbyist will opt to scratchbuild simply for the challenge. Less frequently a hobbyist will scratchbuild out of economy, as sometimes the raw materials cost less than a packaged commercial kit.
Techniques
Most hobbyists develop their skills by building kits, then progress to kitbashing, where various kits are combined to create a unique model before attempting to scratchbuild. Sometimes scratchbuilders utilize discarded parts of other models or toys, with or without modification, either in order to speed up the building process or to allow the process to continue in spite of certain parts being difficult to make. Some companies sell parts that are of little use to anyone but scratchbuilders.
Building stock, in whichever material, can be plain sheets, strips, bars, tubes, rods, or even structural shapes such as L or T girders - stock can also be embossed or textured to replicate a certain prototype material (such as plastic sheet embossed with grooves to mimic a scale brick wall).
For example, to scratch-build a small board fence, the modeler could use plastic rod stock to form the vertical posts, then use plastic bar stock to form horizontal rails affixed to the posts, lay plastic strip stock vertically on the horizontal rails (perhaps 'distressed' with a wire brush to mimic wood grain, or by using thin strips of actual wood), trimming the top and bottoms of the strips to be even, adding details like nail holes (using a small pin), and then finishing and weathering (making a model look like it has been used via dust, dirt, stains, and wear).
Plastic is the favourite material of many scratch-builders because of the ease in which it may be cut, shaped, glued, and finished.
There are as many ways of scratch-building models as there are modelers, but generally the modeler obtains plans of a prototype, or designs his own, transfers these plans to paper or other material as patterns (much easier since the arrival of household computer printers and copiers), and uses these patterns to cut, trim and affix the stock together to form the model. Finishing work (such as sanding and polishing, painting, weathering, distressing by forming dents and rust, dust, etc.) is done to complete the model and (hopefully) bring it to a life-like state.
I do not belong to any RC organization or compete in any sanctioned event/s, but I think some ethical issues exist if one has a kit/other person build the model that claims scratch built status
