RCU Forums - View Single Post - G & L Hobbies Extra 300 build thread
Old 12-12-2007 | 09:59 PM
  #37
Champ-RCU
My Feedback: (132)
Default RE: G & L Hobbies Extra 300 build thread
Irglnman, IMHO, the sheeting that shifted was probably not the fault of the GG, chances are it moved when you put the weight on top. (Ask me how I know:-) If you are only using 30# of weight to put pressure on the skins to the core I feel that you would be very dissappointed in the result if you used epoxy. When I used weight to skin wings 100lbs+ is what I used. This sounds like alot but now I use vacuum and that is easier to control and is a more pressure that is evenly distrbuted over the surface of the wing. Once you try vacuum you won't want to go back to weights. (That is till you get a bag with a leak) That's why I still keep the weights around as a back-up.
Also I will use masking tape to hold the skins in place before I draw a vacuum or put the weights on.
Thanks for showing your build, Good luck.
MTY
