RE: rounded nut
i have done that several times with the cheap screws on my towerhobbies st-15. Just take a smaller bit then the screw and drill it. After you get into you can pull the engine off the chassis and take pilers and unscrew the screw.
cutting a slot in teh screw requires a dremel usually and i dont have one but that sounds like the best idea...
