RE: New CAMODEL Plane
Hello MTK,
I understand the theory of the cannablizer and the common uses for them,..having an aeronautical engineering degree. However, that was some good info. for those who may not. I was simply curious, as the the Pass Port is very similar in airfoil shape, thickness and design from looking at the provided photo,... with very similar fuse lines. I know the Osmose was designed for the cannablize,..so I was told anyway?
I was trying to find a distinct reason between the two "visual" designs, one with and one without, being similar in these areas. I would rather wait for a Pass Port, unless it will be into the late summer. And if not, the Osmose it is! I need a new bird to put my new 170 DZ into,...sooooon!
Bill H.
"Kick the tires and lite the fires and away we go!"
