RE: Camera Reviews?
I didn't check all of the pics but the info is available for the cat pic.
- Primary Image
Manufacturer = NIKON CORPORATION
Model = NIKON D200
Orientation = The 0th row is at the visual top of the image and the 0th column is at the visual left-hand side
X Resolution = 300
Y Resolution = 300
Resolution Unit = Inches
Software = Adobe Photoshop CS2 Windows
Last Modification Time = 2007:06:23 21:24:06
- Exif Specific
Exposure Time = 1/60 sec [0.017]
F Number = 71/10 [7.100]
Exposure Program = Aperture priority
ISO Speed Ratings = 100
Exif Version = 0221
Original Create Time = 2007:06:23 20:48:48
Digitalization Time = 2007:06:23 20:48:48
Shutter Speed Value = 5906891/1000000 [5.907]
Aperture Value = 2827819/500000 [5.656]
Exposure Bias Value = 0
Max. Aperture Value = 30/10
Metering mode = Pattern
Light Source = Unknown
Flash = Strobe return light not detected
Focal Length = 175 mm
Sub-Second Time = 00
Original Sub-Second Time = 00
Digitized Sub-Second Time = 00
Color Space = Uncalibrated
X Dimension (Pixel) = 571
Y Dimension (Pixel) = 800
Sensing method = One-chip color area sensor
Image Source = 03
Scene Type = 01
CFA Pattern = 02 00 02 00 01 00 02 01
Rendered by Customer = Normal process
Exposure Mode = Automatic exposure
White Balance = Automatic white balance
Digital Zoom Ratio = 1
Focal Length in 35mm Film = 262 mm
Scene Capture Type = Standard
Gain Control = None
Contrast = Normal
Saturation = Normal
Sharpness = Normal
Subject Distance Range = Unknown
- Thumbnail
Compression = JPEG compression
X Resolution = 72
Y Resolution = 72
