need some help with my electronics. i had all boards out and since the refiting of all electronics there seems to be a problem with the direction signals because when i push forwards on the stick it will go backwards and if im to push backwards it will travel forwards. [sm=confused_smile.gif] i have taken out the connection for the rear lights from the board as thay are not in use and ive also removed the smoke unit. ive tried 2 difrent transmitters and its still the same and ive also tried changeing the motor wires everyway possible but still no luck. [sm=angry.gif] if anyone knows what this maybe? or has any suggestions then please fire away? [sm=idea.gif] also is it possible to fit tam electronics into a henglong? if so any info on this would be a help please
thanks for reading
