ORIGINAL: SuperCub Man
What is the preferred method of attaching the F/G cowls to the fuse? I would use aluminum "L" brackets and with other aircraft I have F/G'd the "L" bracket to the cowl and used long hex drivers to access the screws to attach it to the fuse. This has not always been successful nor easy to accomplish. Other than that I could run screws through the cowl and into the already attached "L" brackets, but then unsightly screw heads would show on my soon-to-be pristine cowl! I'd appreciate any suggestions. Stickbuilder, how did you attach that gorgeous cowl you have labored on for so long? No screw heads showing on that I'll bet
You lose. With the engine that I am using, I had to mount it with external screws. The trick is to use small screws, and then camoflouge them so that they are not that noticable. The full scale has some fastners and rivets etc on the cowl, so they are not all that much out of place. With the G-26 I would only have been able to attach the cowl for about 270 degrees of the cowl diameter, and that was not an acceptable amount of support for me.
Bill, AMA 4720
WACO Brotherhood #1
