RE: How do I use this hot sock?
Sit your iron on top of the sock, grab the ends of the string and pull them up, one on each side of the handle. then tie them off. That will close the sock on the iron. After you use it a bit you'll notice that it gets very dirty and even gets color smeared on it. That's why you use it. So you don't get that all over your iron and put it back on teh plane.
