RE: WACO YMF
Bill - Further to the adjustable cabanes - it appears that only the rear cabane is adjustable - is that correct? I presume the adjustments will be so slight - if set up reasonably close to the correct incidence - that the front cabane strut joints will be able to take the slight movement created by adjusting the rear ones? (I think that's clear?)
