RCU Forums - View Single Post - How do I use this hot sock?
Old 12-13-2007 | 09:01 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: How do I use this hot sock?
You will find using commercial hot socks will get very expensive indeed as the socks rude up and burn out quickly expecially if you are a monocoat user (a higher temperature application).
Some folks like to use inexpensive baby socks and if that works for you great. I don,t care for that method since its hard to get them so they do not rotate sideways when you apply a side pressure.
So I use the method indicated by Frijock suggested above and this is how I attach them. They change quickly and cost nothing by using three large safety pins.
John
ID:	825049   Click image for larger version
ID:	825050   Click image for larger version
ID:	825051   Click image for larger version
ID:	825052   Click image for larger version
ID:	825053   Click image for larger version
