ORIGINAL: snir2001
No,
Everything seems to be fine. but only 102K
Well then everything does not seem fine.
How did you eliminate a fuel pump issue? Have you tried swapping out to a known good pump? Have you verified that there are absolutely no possible fuel restrictions or possible leaks? Verified the battery is capable of the necessary voltage/amps?
