RCU Forums - View Single Post - Skunk Work Brushless setup help
Old 12-14-2007 | 01:32 PM
goldendesign04
Default RE: Skunk Work Brushless setup help
I will post some shots tonight of the hull. Havent gotten any further since the christmas season is in full swing in my jewelry store. Also have had to report Twisted to paypal, I had notified them over a week ago by phone and email an have heard nothing nor recieved my money (surprise surprise...[&o]) but I will get my money you can bet on that[>:]. Have had a chance to do a little shopping around let me know what you think of my choices.
These were priced either Offshore or Fine Design LET ME KNOW if I should be wary about ordering from either of these guys dont want another repeat
Motor
Feigo540 9XL 1,853 RPM / Volt $69.99
Motor Specs:
6-24 cells in a medium to large sized mono or hydro.
35.8mm dia x 75mm long
5mm Output Shaft. Use 5mm Couplers.
372 grams
50,000 rpm bearings!
Aluminum Purple Anodized Casing
2-Pole Neo Magnets & Compressed Windings
Extra Long Cooling Jacket with 90 degree fittings 21.95
ESC
Castle Creations Hydra 120 $179.99
Programmable with transmitter or Optional Castle Link Computer adapter.
Continuous Maximum Current: 120A
Dimensions (WxLxH): 3”x 1.6"x .6” (76.5mmx40mmx15m)
Weight: 3.2 oz. (93 grams)
Full On Resistance: .00043 ohms
Wire Gauge: 10
Cells w/BEC: 5-12 NiCad/NiMh, 3S LiPo
Cells w/o BEC: 5-20 NiCad/NiMh, 6S LiPo
Or maybe the Nemisis Blue motor/Hydra 120 esc combo for $259 from Finedesignrc.com
dont know anything about Nemisis its only $10 more for them than a Fiego motor any guesses which would be best?????
LIPO
Let me say this I KNOW NOTHING about lipo brands but most had suggested 4s so these looked pretty hot an the price? seems not bad
Firefox Lipoly 4S waterproof $180.00
4S - 14.8 volts
3700 mah
25c rated
14.8volts
3700 mah
75 amp Continuous drain That is Double what a Nimh pack can give up.
Weight is 14oz.
6''long 1-3/4'' wide 1-1/8'' Tall
Any suggestions or comments would be appreciated..I.E. know where I can get this stuff cheaper? A better setup?
Finally
I'm posting a pic of the battery charger I have its worked great on charging my 3s 11.1v 1200mah lipos for my heli an says it will handle all the way upto 5s
any comments on it?
Thanks a lot everyone in advance!!!!!
-Wayne
