RE: How do you add a second motor to the T maxx?
l have to agree with the above LOLs, the two motor thing has been done a thousand times, what people just dont understand is the main gains are torque, but when you incorperate your power to weight ratio, the two motor set up looses every time, the picco owns it, two motors running side by side gives you two pistons going up and down together, not like a twin cylinder engine where one piston fires and then the other fires while the first is at bottom of its stroke, thats a power twin cylinder motor, two of these nitro things next to eachother is a torque power house, nothing more, your truck will never match a true twin cylinder or a single cylinder picco .26 or .28........dont waste u r time basicly.....
